- Joined
- Jun 2, 2016
- Messages
- 54
- Reaction score
- 97
- Points
- 18
My son in law picked up his F/L A3 1.4 tfsi on Saturday. After 6 days and 260 miles while stopped at lights, a 'do not drive car' or such like warning flashed up on the dash and the S-Tronic would not go into gear.
Removing the key a while then attempting to restart had no effect.
After inspection today the local dealership told him they thought it was probably caused by a low voltage (was told 12.1v) was causing a sensor in the gearbox to cause the shut down, and will just re-charge and give it back to him.
Doesn't add up to me. I can't see a low(ish) battery having this effect on the gearbox without showing any other warning lights or symptoms. Unless there's a faulty battery, charging system or electrical drain which they should be addressing then it sounds like a guess in lieu of the real answer.
