How to remove Alumunium interior trim pieces for vinyl wrapping?
Co. Down, Northern Ireland
Hi guys,
Do any of you know how to remove the aluminium strips that run along the doors and across the dashboard? I'm planning to wrap mine as I don't like the current finish on them.
Reactions: RS4dal
Yep, the 3 pieces on the dash just pull off towards you but it really helps if you remove the centre switch panel by inserting two flat radio removal keys into the slots underneath as shown in the middle pic below. The ones on the doors require removal of the door trim pads (not too difficult) as they have two screws behind them as well as a clip and hook ........
rrOkObGD
DVcqeZbJ
UgRE0tnf
Reactions: sjbarneS3, airbus319, Rumpelkillskins and 2 others
Got some parts of the trim off today, the driver's door and little part to the right hand side of my steering wheel. Only got the smallest section done so far but I think it looks great!
Went for what's almost a matte version of Daytona grey to match the exterior :)
Reactions: Naim, Reznor, richinsoton and 6 others
Good work Ryan liking that a lot - wrap looks slightly metallic too ?
Reactions: pburv
Got the driver's door done last night and reinstalled it this morning :) love the metallic in the vinyl when the light catches it!
Reactions: Tej13, richinsoton, Dunedin and 3 others
I feel like this is going to be a stupid question but as i've never done it i don't really know - would it be viable to remove the trim inserts and paint them a different colour? Just thinking what with them being part metal and what not.
Yeah no reason why not mate just prep them as you would paint any other metal part.
Reactions: pburv and CarloS3
I was thinking about painting mine too, until I removed one to see what the trim piece actually looked like and what was underneath. I guess I assumed that the trim was "aluminum-look", but it is, in fact, real aluminum and this made me hesitate to paint it. I've ordered some samples of vinyl wrap and might see if I can get something close to what I want so it can be removed easier in the future.
Yeah I'd wrap mine too but I want to colour match mine to panther black. Don't like the idea of painting my only set, but at the same time I don't fancy shelling out for a full set of trim inserts haha
Very nice wrap job on this! I'm currrently wrapping my dash trim pieces and am having difficulty getting that piece off in particular. Any tips or tricks you can share? Does it just pull right off or does it take a bit of finesse-ing?
Reactions: Rob2k68
That's the easiest part to remove out of the lot of them. I used a trim removal tool, got it underneath it and popped it right off
Reactions: Rob2k68
I did actually get it off but it was the most difficult on my car!I had to use two hooks behind the edges to haul it off as the trim removal tools weren't doing anything and even putting it back in was a struggle. Managed to scratch the aluminum a bit too although you wouldn't be able to see it unless you went in with a magnifying glass. :grumpy:
Reactions: Panda0425
Managed to remove the parts on the dash easily enough, just needed to use radio keys to pull out the button row (parking sensor, driver select etc.)
Never wrapped anything before but even with a heat gun was struggling to do the corners and the funny angles of the trim pieces. Had to give up :(
Not sure if the vinyl was like the wrong kind maybe...? Was just some cheap stuff from ebay, not sure if it should have become more stretchy when heated.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/320950861034
I feel your pain. The small piece with curves on both ends closet to the driver door was definitely the toughest one to do. It took a LOT of heating and repositioning and then some more heating and repositioning and then a little more. I think I went through about 5 different pieces of vinyl before finally getting one to work. I found it worked best if I got the center portion attached all the way around, then heated one end section *really* good and pulled and stretched it out right over the rounded end bit. I now have a lot more appreciation for the people doing this every day in their jobs!
rrOkObGD
DVcqeZbJ
UgRE0tnf
@Rob2k68 - Thread Revival!
Would you happen to have the pictures from your post back in July 2016? Long shot I know, but would be much appreciated.
Reactions: Rob2k68
Crickey that’s going back a bit LoL ....
Slots are just under the outer buttons shown by the red arrows here ....
Reactions: SPIKE_
Thanks for that. I assume two flat pieces of metal would work just the same? Unfortunately I don’t have radio removal keys :unamused:
Reactions: Rob2k68
Yes would probably work but the keys have a curved lead in have a look on eBay and just copy the profile.
Reactions: SPIKE_
Thanks @Rob2k68
Replacement paino black trims fitted to the dash. Now for the doors :grimacing:
FC522CA0 D27F 494D B9BC 9205619CC5CB
Reactions: Rob2k68
