Coolant
A3Kent
Hi All
My Coolant level is below the minimum level (not by much) - had a warning come up on the dash yesterday.
The owner manual says to get some G13 so I've located a bottle on eBay (genuine stuff from a proper Audi dealer eBay user).
The owner manual suggests a mix ratio of 40/45 coolant and the rest water. They have advised a 50/50 mix ratio as it works down to -36 degrees.
Does this all sound OK to you guys?
Hi All
Does the manual actually suggest normal water ?, my old Golf R specifically stated distilled water (not tap water), its also worth keeping an eye on it as my R had a leaking water pump.
Reactions: A3Kent
It's due a service soon so i'll get them to check it then but in the meantime i'll top it up.
Picked up a 1.5 litre bottle of G13 coolant concentrate from my dealer this morning for £12.53 which seemed reasonable.
Dunno about what you guys think but in my opinion modern cars should not loose coolant unless there is a problem. I've recently had the water pump changed because of coolant loss as have quite a few others on here. The S3 is a private purchase but all the company cars I've had in the past and the hundreds of thousands of miles driven I have never had to top up the coolant in any of them.
Mines topped up now. I will be monitoring it and it will be reported when it goes in for it's first service in October.
Mine was drinking coolant for a while. The last time it went in, the tech filled it about 2cm above the Max level as per the TSB and it hasn't used a drop since.
Both times it went in it was tested and no leaks were found. Done over 10k miles now since it was topped up.
Reactions: A3Kent
Mine was at Audi for loss of coolant on Monday, got it back Tuesday with a new radiator. Apparently the one it had in it was leaking at the seams.
Reactions: A3Kent
Mine did this for about 6 months from new........never gave me a warning but went lower than expected. Suddenly stopped doing it. I'm convinced it's an air lock type issue out of the factory.
Reactions: A3Kent
15
506
19
