A variety of faults reported :-/
iainjo
I've recently bought a 2009 A3 TFSi Quattro, it may have been prudent to do a full check beforehand but I wasn't able to borrow a VCDS cable until now. There is what appears to be a comprehensive warranty so I've run a scan and a number of fault codes have popped up.
I'm pretty much a novice to VCDS so ran an auto scan, it may be warnings over nothing (I hope) but would someone please cast there eye over the faults and advise whether I should be off to a garage, thanks.
I can't seem to attach a text file, only an image so apologies for the lengthy post. I've trimmed some of the fault info out to keep the post size down. There are a number of faults from earlier in the year, I take it I'd be best clearing these (not quite sure how?) and running again? Also a lot of messages relate to "under voltage" with 10.5V being a common reading, dodgy battery?
Thanks in advance - also can anyone recommend a good VAG indie in South Yorkshire, ideally Sheffield?
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
4 Faults Found:
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Freeze Frame:
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Freeze Frame:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
4 Faults Found:
01487 - System Function Test
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
00532 - Supply Voltage B+
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
5 Faults Found:
Freeze Frame:
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Freeze Frame:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
1 Fault Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
1 Fault Found:
Freeze Frame:
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
1 Fault Found:
Freeze Frame:
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
2 Faults Found:
Freeze Frame:
Freeze Frame:
Address 55: Headlight Range Labels: 8P0-907-357.lbl
1 Fault Found:
Freeze Frame:
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
2 Faults Found:
Freeze Frame:
Freeze Frame:
Address 77: Telephone Labels: 8P0-862-335.lbl
2 Faults Found:
Freeze Frame:
Freeze Frame:
Looks like a flat battery occurred or its got low, as above, clear & rescan.
That's a bit better, cleared the codes on each module and this is what's left, just the air con faulting.
One other question, I was browsing the modules and checked the Headlight Range Control, mine's set to 0000013 which says is for the A3 (8P) Cab. I'm not sure if there's a huge difference or advantage with that setting but shouldn't mine be 0000002 for A3 (8P) AWD?
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000295 Serial number: 8P0820043BM
Shop #: WSC 00586 210 81414
VCID: 78F870CF0BC0ECFE65-802C
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 108
Mileage: 105063 km
Time Indication: 0
Date: 2012.01.13
Time: 08:36:28
Freeze Frame:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 108
Mileage: 105063 km
Time Indication: 0
Date: 2012.01.13
Time: 08:41:34
Freeze Frame:
Seems you've enabled system function test, may need to contact ross-tech to disable if its not a selectable option.
Thanks, I shall take a look and if needed contact them for advice.
This may be of use to someone searching the forum but those last issues are resolved, just one new intermittent brake circuit error which is new.
As NHN advised a system function test had been enabled and it was waiting for me to run those tests.
So I followed the following process to clear the fault codes:
  • Have the car running at idle
  • Select controller and then Basic Settings
  • Set the Group to 003 (as per the error), click Go! and then ON/OFF/Next - The test can take up to 10 mins I'm told but was under a minute on mine and then the Feedback Value came up System OK
  • Repeated for 004 and all done. Cycled the ignition and codes cleared.
Upload 2016 8 4 11 58 39
