Anyone know if the complete rear lights from the 8v fl will fit and work on my 2015 8v, plug & play??
Pre FL clusters have 5pin connectors and FL have 6pin. Fitment is the same but rewiring is required and then coding.Anyone know if the complete rear lights from the 8v fl will fit and work on my 2015 8v, plug & play??
Parts from Audi work out to approx £320 per side...... and lots of £££ in the first place to buy them !
Easy enough for an auto electrician then?Pre FL clusters have 5pin connectors and FL have 6pin. Fitment is the same but rewiring is required and then coding.
If they have the correct wiring and coding information yesEasy enough for an auto electrician then?
If they have the correct wiring and coding information yes [/QUOTE
I want a set, I saw them on a fl yesterday on the m6
Been interested to see how you get on with itI am working on this as a project at the moment
Have already retrofitted the lights to a test car with no issues. Just working on getting the prices of the units down.Been interested to see how you get on with it
Will post up a video later when homeAny before/after pics Alex ?
SaloonCool thanks ;o)
Just to wet our appetite was is it a Sportback or a Saloon ?
@RedS3Reilly - More info here on this topic (one of your old threads )Anyone know if the complete rear lights from the 8v fl will fit and work on my 2015 8v, plug & play??
Got my LED rear clusters installed and upgraded.
Should be more or less the same as the above video.Post the video @Kieran Johnson a good few will be interested if it's that price.
True, but I am thinking about the "effect" more than fitting.Unless it's a fitting guide with adapter shown???
They are the semi dynamic ones and you can adjust the speed to your preference. Here are my ones installed.. Sorry if these are not what you are looking for, let me know what you guys think.
https://vid.me/iU0Z
Nah they are just plug and play adapters, no coding needed. Just have to remove the outer tail light. All the adapters do is set a delay from the inner light therefore making It semi dynamicAre these standard and tweaked via VCDS?
The vCan this not be done through vcds?
Know of a few owners who used vcds on their mk7 R's to get dynamic headlights.
Where do you get these from and at what cost?.....they look the biz!
