A1 Heater slows down?
MFZ
Devon
Has anyone experienced any blower issues with the A1.
Ours is a 2013 185ps BE with the 3 silver heater controls
If the heater is just turned on and set for full power it runs the you can hear and notice the heater slows and the air flow drops almost to nothing at times?.
The Auto is turned off , AC is off , doesnt seem to matter where the temp is set to.
When you turn the heater off you hear a whooosh sound from the passengers side ?
its been in to Audi 2 times so far , the first time was told it didnt do it so i showed them it does it every time .... oh yes we will get it back in... the second time have been informed they have contacted Audi UK and its programmed that way ?
They didnt have any A1's with the same type of heater to compare it to and returned the car again.
Ive since had the RAC fault code the car and came up
U102500 Read fault codes in Climate control System - intermittent
Can anyone shed some light on this code ?..., have any experince of this fault? ...Have an A1 with the 3 silver dial heater can tell me if it will run full speed and not slow and does it whoosh when turned off like the flaps are moving?
Any info appreciated before we take this further as its still under warranty and would like this sorted before the winter when we will need the heater/blower working as it should .
thanks
10
827
695
