so today my TT engine cover arrived. I pulled my bonnet release and I think it snapped. I can see the cable is still attached to the pull handle. So how in the name of God am I going release my bonnet?
Can you explain more detailed? I am in the same situation as you, I'm about to give up... Saw your comment but cant seem to find the cable? I can't even see anything in that little hole... Help please!Just a little update in case anyone else encounters this problem. Problem solved.
I took out the wheel arch lining on the drivers side. Absolutely no access. Tried putting weight on the bonnet etc. nothing. Looked under the bumper...impossible. Almost gave up. Here's how I did it..
If you look through the front grille above the Audi badge you will see a plastic cover where you would imaging the latch to be. There is a small square hole in it...If you reeeeeelly look through that hole, you can just about see a cable.
Get a bit of strong metal (I used an old dip stick) and make a hook on the end. Feed it through that hole and with a bit of patience you can hook the cable and pull it. Job done.
Here's a pic of the hole through the grille
