What an absolute idiot! Help :(
S3_Mitch
Money pit owner
South East
What the **** have I just done :( in an attempt to secure my wmi pump to the boot floor I have just drilled into the top of my fuel tank! Right when I'm supposed to be running my car in with limited time before mapping I do this? What do I do? Help please..
have a fag inside while you calm down
Reactions: AdzA3AGU, James_TDi, superkarl and 6 others
Get a new tank or weld over the hole but make sure there's no fuel vapour left in tank or you will lose your eyebrows
Repair?
Doing anything (hot) to repair a fuel tank is potentially dangerous. I strongly suggest you seek assistance from a specialist who can repair these, following the proper safety precautions.
Or, if you can access the area, this may be worth a shot: Amazon product
Change the tank. Drop the prop, exhaust, 4 bolts and the In tank pump.
Could you not epoxy a patch onto it so you don't actually put anything in the hole, just over it?
Personally, I would just glue and tape over it, but I drove around a T25 camper for 4 years with a festering fuel tank meaning you could only half fill it otherwise you would leave a trail of petrol.
#firehazard but only for a few seconds
I've tried some epoxy glue, I can access the tank easily through the boot floor the keep an eye on it. It's the highest and furthest back point on the tank lol
Tap the hole, screw in a hose tail and run a pipe up beside the filler neck, so it acts as an extra breather hose.
