Problem wiring epb
Andrei1987
Hi there. I have a lot of problemes, I now have a problem with the epb. I have a bad wiring and bad conector of the electronic motor, like these photos, I check the fuse is ok, the other parking brake works fine, but the left one doesn t work, the cable it s bad, but I check with the handbrake on and after with the handbrake off, and at the wiring end doesn t have voltage, 0 voltage. The voltage ussually is when the connector is connected with the motor or it has to be at the end of the cables?
427
697
4K
