Engine and chassis codes
Roadtrain
Audi S3 8L 225 "BAM" from Italy :)
Italy
Hi to all, how we can verify codes about engine and chassis car both? Where are located these datas exatly? This is a good way to verify if engine is the original one or not. Thank you as always :)
Engine code is on the head, engine number is on the block... check them on your documents... there is also a label in the boot with all the option codes, chassis number and engine code on it..
You can use this to decode the options
http://igorweb.org/decoder/howto.html
Reactions: Roadtrain
Thank you. I found chassis code easy (under plastic cover located between windscreen and bonnet), but not engine one: I need lift car and see on engine "block"? Do you have any picture? Because I don't think I translate correctly this word. Thank you.
there should be a sticker where the spare wheel is telling you engine code
otherwise
ciao ;)
Thank you :) Yes I found that paper sticker where the spare wheel when I controlled if colour is "Brilliant Black" or "Ebony Black".
otherwise
ciao ;)
Grazie :)
Thank you :)
Is that code in the red circle "APY", "AMK" or "BAM" only, or is it an unique code as for example "BAM123456789ABCDE"? I would follow this way to understand if engine is the car's original one or not, because I can't recognize a different one if it's "BAM" aswell without more numers/letters indicated. Can I check it disassembling engine's plastic cover only? Thank you both again.
948
897
575
827
