Not sure if your magride is working or not?
Well here's a handy guide to the two tell tale sings that's that all is not well in your magnetorheological world.
Most obvious symptom, until you start moving, is this;
Should that escape your notice though, then the comical lack of bump and especially rebound damping will be alarming, slightly nauseating and cannot fail to grab your attention. The oscillation and pitching over bumps is highly disconcerting, and the bouncing is occasionaly sufficient to almost throw you out of the seat. In short, the car becomes ****** horrible to drive.
This of course means that Audi's mag ride system is doing rather more for its living than I'd first supposed. You can of course tell the difference between comfort sand dynamic modes, but nearly as much as you can tell the difference between any mode and fully off.
