To increase radio play time after car is turned off:
In the Hidden Menu:
MMI 2G:
"MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
MMI 3G:
From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes.
