Hi All.
Today i decided to change the upper rear track control arms and all four outer bushes on the s3 as i had the creaking getting worse by the day and also had play on the inner bushes on the top arms.
Looked up the part number on partslink which came back with 1JO 505 323 L upper track control arm.
I crossed this number over to firstline which came back with part number FCA7105 upper track control arm so i purchased 2.
After everything was fitted then tightened when on the ground i have noticed i now have negative camber?
New arms was measured against old before fitting and the lengths was identical.
Is it possible that the hole on the fork end of the new arm is in a different position to the original arm?
I did not think to check i just held the arms side by side.
Advice greatfully received.
Also is it possible to change the inner bushes ( standard type ) on the old rear track control arms?
