Haven't asked the question yet - I did wash the car though yesterday. when I joined the Forum - you need to wait for a couple of days to get your account verified. once I get around to it I will update here - the Unregistered Lite version is pretty limited - I don't want to pay $99 then find out I cannot log the bits I need powertrain wise and set up the "can" <-- I think for the Symphony 2 - and then have to pay for the cable version in the end.
I also need to spend some time looking at that Visual Studio free logging app "VisualME7Logger" - just no time at the moment.
According to the charts on VCDS
http://store.ross-tech.com/shop/VCDSLiteReg.html <-- you can use the $99 as a credit for full version.
Limitations of VCDS-Lite compared to VCDS even if Fully Registered:
No Generic OBD-II
Won't work with CAN-Bus vehicles
Fewer fault code definitions and label files <-- these are all lookupable
No built-in Activation (you'll be limited to a single PC) <-- says you need to copy the licence key from one pc to the next
No Advanced Measuring Blocks <-- don't know what this includes?
No Acceleration Measurement
http://www.ross-tech.com/vag-com/vag-functions.html
it looks like it should work if you pay the $99 for measuring blocks?
Function Number / Name
00 Auto-Scan 1001.01
Registered Version Only
01 Control Unit Info
Yes
02 Read Fault Codes 004.01
Limited unless Registered
03 Output Tests 005
Selective Output Tests 005 No
04 Basic Settings 006
05 Clear Fault Codes 004.10
Yes
06 Close Controller 022
Yes
07 Code Module 007 (Service 1A)
008 (Service 22)
Yes
Code Slave Modules 007 (Service 1A)
008 (Service 22) No
08 Measuring Blocks 010.02 (KW1281)
011
09 Single Reading 010.01
Yes
10 Adaptation 012
014 (long)
Limited unless registered
11 Login
(called Coding II
under KWP-2000) 015.01
Yes
15 View Readiness 020.01
Yes
16 Security Access 015.02
18 Supported Codes No
33 Generic OBD-II No
Freeze-Frame Data
Dual K-Line Support Yes
7-Digit PINs (VAS only) 020.07
Code Database current through MY 2012
Current through ~2006
Diagnostics via direct CAN connection No
(with CAN Interface)
Transport Mode (VAS Only) 1001.03 (on)
1001.04 (off) No
(with HEX+CAN Interface)
Advanced Measuring Values No
Guided Readiness Scripts No
Support for Dual ECUs No
Data Logging
(Factory tools cannot do this!)
HighSpeed DataLogging
(Factory tools cannot do this!) No
(with HEX Interface)
Real-Time Graphs
Real-Time Gauges
Graphic TDI Timing Checker
Not for V6 TDI
Control Module Finder
Yes
Automated Service Reset
(SRI) No
ECU Mileage Checker
(Many EDC-15/16 ECUs) No
GeKo/Fazit on-line access to Immobilizer Codes and Component Protection No
