No Bluetooth phone connection
A noddy
Renfrew
Hi I'm having an issue with my phone connection in my 2009 audi a5 cab.
I did a scan with vcds and it's thrown up a few codes 01303 ...03041..02256 any ideas would be greatly appreciated thanks
this has took me a while with my blooming laptop , but here it is the full scan thanks for the reply.
Sunday,11,September,2016,13:11:25:09930
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ8F5AN005061 License Plate: K900JCR
Mileage: 74540km-46317mi Repair Order: 11.9.16
Chassis Type: 8F (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 26 2E 42 46 47 52 53 56 62 72
77
VIN: WAUZZZ8F5AN005061 Mileage: 74540km-46317miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
26-Auto Roof -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AJ HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0002
Revision: E1H14---
Coding: 011C000C18070060
Shop #: WSC 00636 210 81845
ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
ROD: EV_ECM20AVS.rod
VCID: 77F9B49DCEEB8EFA91-8022
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Revision: -------- Serial number: --------------
Coding: 060500
Shop #: WSC 02391 823 56573
VCID: 7CF3ABB1FFCDADA2FC-8028
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BP HW: 8K0 907 064 BP
Component: BCM2 1.1 H90 0247
Revision: 00002001
Coding: 031300
Shop #: WSC 02399 823 56573
VCID: 7F095CBDEEDBB6BAD9-802A
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000022677016
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000027351014
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0150
Revision: D1000000 Serial number: 01140420091679
Coding: 64070000
VCID: 4381104DC2B3125AFD-8016
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 G HW: 8K0 907 063 B
Component: BCM1 1.0 H26 0372
Revision: 03026001 Serial number: 00000000349593
Coding: 690000110034A7010005000300005F5F001D028800000141000000
VCID: 3361408D9213A2DA6D-8066
Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150710 H05 0021
Serial number: SWF10070155193
Coding: 005914
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10469294
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Serial number: 00000000002304090981
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 F HW: 8K0 919 475
Component: PARKHILFE 4K H06 0040
Revision: 11001001 Serial number: 40140913212166
Coding: 000001
VCID: 3C736BB1BF4D6DA2BC-8068
Address 15: Airbags (J234) Labels: 8F0-959-655.clb
Part No SW: 8F0 959 655 HW: 8F0 959 655
Component: AirbagVW-AU10 H08 0430
Serial number: 003A4D041NN
Coding: 30363635353130303030554A305238463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 75E5BE95D4E7FCEA83-8020
Crash sensor for side airbag: driver side:
Serial number: 6334MSME46630F018
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4701074EB
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME3728000C9
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME2F273D28U
Crash sensor for front airbag: driver side:
Serial number: 63732SME1023360ES
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME11250D1E.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315IEB000BH
Coding: 000012
VCID: 3D7566B5A45764AA8B-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 A HW: 8T0 920 981 A
Component: KOMBIINSTR. H32 0224
Revision: 00200000 Serial number: 9D3665L49
Coding: 2F04180002002600010000
VCID: 3A7F6DA9B5795392AE-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G0950583A8
Coding: 000303
VCID: 4B91386DEAE3DA1A05-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 190781CA210409
3 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 247
Mileage: 73250 km
Time Indication: 0
Date: 2016.06.17
Time: 12:36:00
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 68
Reset counter: 230
Mileage: 74363 km
Time Indication: 0
Date: 2016.09.04
Time: 17:43:33
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 13
Mileage: 74527 km
Time Indication: 0
Date: 2016.09.07
Time: 19:37:00
Address 26: Auto Roof (J256) Labels: 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H09 0160
Coding: 010000
ASAM Dataset: EV_ElectRoofContr 001007
ROD: EV_ElectRoofContr.rod
VCID: 71ED8A85A08FD0CA5F-8024
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H08 0210
Revision: 00000000
Coding: 020202
VCID: 78FBB7A1CBF5818298-802C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000101048804
Coding: 011042724009330C03
VCID: 45850E55CC872C6AD3-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0118082044
Coding: 011B06A0003904600030030000000000
Subsystem 1 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6ED791F9B9B1CF3242-803A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 230
Mileage: 74363 km
Time Indication: 0
Date: 2016.09.04
Time: 17:43:33
Freeze Frame:
Voltage: 14.10 V
Temperature: 26.0°C
Bin. Bits: 00000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000100911268
Coding: 011042324009330C03
VCID: 44831351C7BD1562C4-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000363754
Shop #: WSC 00000 000 00000
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H02 0310
Revision: 00000005 Serial number: AUZ5Z6I1203028
Coding: 0402008201038D00035B070800
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 74342 km
Time Indication: 0
Date: 2016.09.04
Time: 13:58:27
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 230
Mileage: 74363 km
Time Indication: 0
Date: 2016.09.04
Time: 17:43:33
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000101036995
Coding: 010002324009370C03
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101036571
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:10)--------------------------
Cannot be reached
Looks like you've lost comms with your telephone module. Check fuses and the wiring to the module looking for live and earth feeds. If they are alright you are probably looking at a new module.
Thanks for that I've checked the fuses any idea of the location of this module ? Is it under the seat ? Drivers side or behind the glove box? Audi A5 cab cheers
I'm not 100% sure on the a5. I know the module on my a4 is under the center consol. I'll try dig out the location when I'm back at my laptop.
Cheers again ...this is where I need the old Haynes manual like I had for my fiesta ha ha
Haha Haynes manuals always confused me the way they were layer out.
Looks like your module is under your passenger seat.
You should get on ebay and get hold of a copy of elsawin much better than Haynes
Superb , thanks for checking that out. I'll have a look at getting elsawin.
Audi Sport-Net is why I love Audi and Have 3 A1, A3 and my A5 ...cheers
Reactions: EXSpartan36
