I while back I posted about my concerns on my AEB with 191,000 miles, used every day and runs well.
So I decided to install an Oil pressure gauge this week end, I bought a VDO gauge white faced and fitted the sender via an adaptor by moving the oil pressure
switch, all good and no leaks.
Wired it all up, started the car and got a reading so all good.
the next morning from cold, I started the car, the oil pressure gauge would only reach 40psi,
So went for a drive to warm it up, the idle pressure was about 13psi and when I went driving the gauge would only go to 40psi and would not go over that.
So it looks like I'm ready for a pump replacement, if I can believe the readings, as I cannot understand why the gauge will not go over 40psi?
