Leaving/coming home lights
JamesMadog
Evening guys,
Does anyone know if it is possible to get the coming/leaving home feature on an audi S3 8P3 59 plate? Ive seen a few on youtube that when you unlock the car the drl's and the fog lights come on and same when you lock it they stay on for a certain amount of time.. Is it possible to code this in?
Thanks in advance
Think its only possible if you have the auto-lights?
I'm sure someone will be along to confirm.
In a car properly set up you have a light sensor in the rear view mirror - if you don't have this you can do it by putting a short in the wiring to simulate the light sensor saying its dark, with that and some vcds coding you can make it work - but as I say it will operate whether its dark outside or not.
Details are here http://audiretrofit.quinlivan.net/cominghomelights
This is for the Pre-Face lift, I did this trick on my old car.
Un-sure if it works on Facelift as its all different.
I have an A3, MY09 - I have auto-lights and a little button under the light switch where I can activate/deactivate the coming home lights. Using Carista OBD-II I've been able to activate the Leaving Home feature too. TBH I don't really use either...
Reactions: Spike1979
I looked in the computer and when i go onto lights the only thing i can change is the amount of times the indicator flashes, can anyone point me in the direction of someone that might be able to do this for me?
Facelift cars dont like this, only 100% success would be the full retrofit of which we've had 100% success rate :)
Mine is 59 plate with out auto lights but managed to turn on coming lights with Carista, if I can remember you can select which light you require to be turned on fog or dipped beam.
Mine is 59 plate with auto lights but managed to turn on coming lights with Carista, if I can remember you can select which light you require to be turned on fog or dipped beam.
Yeah you need auto-lights fitted with 2009/2010+ I have the leaving home active but only when I flash after I leave the car.
Sorry edited it without auto lights. Yea mines the same if I flash then they stay on.
I want to figure out if it's possible for the lights to come on when you lock and unlock the car like the Pre-Facelift.
Oh right, my mate has an a5 estate and it looks pretty cool his fogs come on when he unlocks the car.
I have just been told this can be done on Facelift without autolights.
Trying to gather more info.
Reactions: S11M
I originally had the vcds coding tweak for the coming home lights on my 59 plate my10 S3. As has been said you have to flash the lights for the coming home to work and the leaving lights never worked.
I have however since completed the full auto lights/wipers retrofit and have full coming home and leaving lights working with the fogs enabled.
It's by far the best retrofit I've done, mainly for the light and wipers, the rest is just a bonus.
It's not the simplest or cheapest retrofit but well worth it.
I can write a program using a micro controller and make a custom harness to enable any light. It's cheaper than retofit but obviously custom job.
I don't have to flash the lights to switch the CH/LH lights to work, they always work when light switch set to auto. Can be enabled in DIS.
Mines a facelift 2010
Reactions: Essflee
How much did it cost in the end?
That's because yours has the auto lights already installed?
£160 for the screen
£40 for the switch...ebay (although you can apparently use the original facelift one)
£40 for the loom....kufatec
£100ish for the mirror and sensor etc.....eBay
Then it was just my time fitting and coding it all
Reactions: Chell85 and Dannymoto
£160 for the screen
Not as much as what I thought.. something to look into
Do it, it's a god send this time of the year.
I know it's easy to just do it manually but why the he'll should I, after all I don't even have to change gear either lol!
@-Ju-
Can you help me with coding for this .. I have done this retrofit to my a3 2015 s line
£160 for the screen
-Ju-:
Can you tell me a step by step process of this... I've done the switch and the sensor but where do I put the kufatec cable..... ????
And help with the coding
Sorry pal, as I said before it was a while ago now and can't remember the process.
I'm sure the kufatec cable came with fitting info though
Reactions: Chell85
-Ju- I have lost the email that the instructions for the kufatec cable
Dam OK thanks anyways
