EGR Oil Leak
6833jon
I have a 1.9 tdi, and there is oil leaking from the side holes of the EGR valve, and also the at the bottom junction. Does anyone have any experience with this problem, and what I need to do to stop it please?
IMG 5482
Perfect , no eml from egr disable .
Pull and plug the egr vac line .
Clean and plug the two atmospheric egr holes .
My erg is lot worse than that covered in oil. I think I need a new one, mine is an 05 plate so I guess I can just blank it off.
I thought it would. I might just get hold of a second hand one. There butter fly valve is missing off mine and leaks oil alot.
Had the inlet manifold off to check it wasn't stuck in there. Wasn't clogged up which is good, but leaking oil quite a load from the egr
