Bonnet vibrating
Stuart B
I have checked to see if I left a tool somewhere but has anyone had to change the rubber stoppers or similar, it's quite annoying now and has only just started happening.
You're the tool!
No,you're the tool!
(car share)
But seriously mate,you should be able to 'wind' out the rubber stoppers on the underside of the bonnet a certain amount to make the bonnet shut tight.
I expect a man of your calibre already knows that,but just in case :blush:
Check ya bonnet catch assembly, the 4 bolts that hold it in place might have come loose. I had a similar issue a couple of years back, all four bolts came loose for some unknown reason
Steve
I did notice the boot / grommit things so will see if they are adjustable still, I will check the catch though too as the other day when filling up with fuel I noticed the bonnet was not shut.
The small things hey
C
5K
