Steve Bryce
- Joined
- Dec 20, 2016
- Messages
- 6
- Reaction score
- 1
- Points
- 3
Hello all, I am tearing my hair out with this one.
I have a 2004 A3 with the 8P engine. I had the common issue, of the coolant temperature not going above 70. After reading on here, I decided to change the thermostat. The problem has now changed, but not been cured.
If I drive for between 5 to 10 miles, the gauge will hit 90. Soon after it drops quickly down to zero (or 50 as the gauge says). A while later it will start to rise again. Sometimes, it will get near to 90, and then drop back down. Other times, it will hit 90 and stay there. I can't seem to find any pattern to which it will do.
The heater works, as expected, take around ten minutes to warm up, and then stays hot.
Radiator fan comes on from cold, but not just a little, it runs extremely fast for about half a minute, then slows to almost stopped, for around a minute, then it speeds up again, and this keeps repeating. Strangely, this behaviour stops on the occasions when the gauge does read 90.
Something I found even stranger, is that when looking into this, I was feeling hoses in the engine and found that the hose on the right of the engine (when viewed from the from), that has the CTS attached is hot (though nowhere near overheating how), and yet the thermostat housing is cold. Not just cool, but cold, as though there has been no heat there at all. I have tried this with the gauge at 90, and also when it has dropped.
With all this in mind, the car runs perfectly. The only minor issue is the known hot start problem (but only takes 3-4 seconds to start), and this only happens when the gauge actually reads 90. Aside from that it is as expected.
So my confusion is this: if the thermostat (which is new) was stuck open I would expect overcooling, and the thermostat housing to be warm, and the gauge to rarely reach 90. However, if thermostat was stuck closed, I would expect overheating, not the gauge dropping. I have read that the CTS can cause issues, but I imagine that this wouldn't leave the thermostat housing cold. I have also considered the coolant pump, but once again I would expect the engine to overheat if that was the problem. Regarding the radiator fan, I haven't had the car long enough to know if this is normal, but it does appear a strange behaviour.
I realise that variants of this question have been asked before, but I am at a loss as to what to do next, and I can't afford to start randomly replacing parts, unless I'm reasonably certain they are going to cure the problem. Given the cold thermostat housing, I'm not sure if my question really matches the others that I have read.
Any advice on this, or even suggestions on how to test which part is at fault without actually replacing would be very much appreciated.
Thanks in advance
Steve
Thanks in advance
Steve
