Door warning lights & puddle lights
Peter Metcalf
Monkey magic
Doncaster
Hi Guys
I've tried searching for a "how to" on completing the retrofit of the door warning lights and puddle lights to my A6c7 can anyone point me in the right direction.
No not yet I can get a set of OEM puddle and warning lights with wiring looms from AliExpress for £30 or I might see what Trups can do them for, do you think they will need coding via vagcom
Can I ask how much for I've got front puddle lights but nothing else in the rears or front warning lights I've got vcds so codings not a problem I guess you fitted some then were they easy to fit
It was £30 per door for the rears but that included everything and Robin labelled it all up :)
Hardest bit was cutting the door card for the bottom puddle lights but the outline is there :)
Would you be so kind to share the link ?
So if i understand this right i could fit them and code them with Vag com and that's it ?
What link?? @RobinA3 is a member on here and the door card removal is a thread at the top of this forum sub section
And yes they are very much a DIY job. If you can operate a screwdriver and a stanley knife you're good to go
sorry should have been more clear, I mean for the light and look combo
ah sorry I see yes, didn't really understand :)
I can supply these kits to you for £30 per door which includes the custom made looms and OEM lights. These are the same as the kits Trups supply ;-)
RobinA3 what if my front doors has the puddle but no warning lights is it still the same price
9
3K
685
811
