Seems quite essential as my car doesn’t come with a spare ! =) Still looking for the bracket part No.
Just ordered all the parts to add direct TPMS to my car. Found a receiver for £30 on as saved search and then the harness and 4x sender for about £80 so £110 all in very reasonable. The only thing I'm having trouble with is the bracket for the receiver, I can't find it in the parts catalogue any where does anyone have a location and part no. for it please .
Very nice but an extra problem (and expense) when changing a tyre.
No spare? Absolute madness
Bracket: 4E0810675BSeems quite essential as my car doesn’t come with a spare ! =) Still looking for the bracket part No.
What websites did you order from?
The TPMS module itself will need parametrising before it’ll work properly.
If it’s a virgin module that is.
Bracket: 4E0810675B
Screws: 2X N90809802
I also ordered the kit. Today i hope to receive my loom and receiver.
A3 8V Facelift Limousine
As your looking at the back of your car the modules factory location should be on the right, behind the bumper. Don’t bother putting it there however, just put it in the cubby hole in the boot.Is that for the saloon ? I am still struggling to find where it should be on the hatchback as apparently it’s location is important to correctly identify the wheel position .
Yes the seller said this . Is this a VCDS only thing ? Or can I use somthing like OBDeleven ? May be the excuse I need to buy a proper VCDS setup....
Yup, can parameterise@DJAlix Is the peramiterisation something you can do ? Or have I bought a dud ?
Sent you a pm.I am having trouble with my installation. i have had the sensors fitted today along with a new set of tyres. I have installed the receiver into the rear drivers side cubby and have connected the ground and live and the CAN lines to the black connector in the passenger door well pins 2 and 3 matching colours.
I have mostly followed this thread
https://www.audizine.com/forum/showthread.php/824924-Direct-TPMS-Retrofit-Guide
I am afraid I have done something wrong though as I have not even seen the TPMS page on either the MMI of VC, and now can't get it to even revert back to indirect...
It may just be late .....
https://m.aliexpress.com/item/32866...pm=a2g0s.13010208.99999999.260.26cd3c00KQL0zb
the fact that the module is new was my concern. Alix is a bit far from me except when up visiting Scotland.
https://www.aliexpress.com/item/TMP...QB-CARS-Tiguan-Passat-B8-NEW/32866483455.html
(non mobile link)
I'd double check they are the right part Numbers for the A3 8v
Have a chat to him anyway he may be able to help you out, he has been incredibly accommodating with things for me .
can never have enough toysThat’s another thing on my list now.
You guys are costing me too much money
Feel the tpms should be factory fit especially if they hand out tyre gunk or a space saver wheel.
Didn’t think power(memory) seat were available?I think I have run out of toys to add to mine except for power seats but that's too much hastle until they are really worn ....
That’s what I was thinking. Easy enough to fit, mate have access to tyre machine and I can do the wiring.https://m.aliexpress.com/item/32866...pm=a2g0s.13010208.99999999.260.26cd3c00KQL0zb
One of the things I miss the most going from my a6 cause the mrs occasionally drives my car and it takes me ages to get it back right.
Modules on Ali are not parametrised.
So this means once these kits are installed you need someone with ODIS to get it fully coded?
The TPMS module needs parameterisation off the car....
As others have said Alex can do this.
Once done and coded correctly (removing the indirect TPMS) everything works perfectly.
Is your TPMS module brand new? If so has it been parameterised for use on the A3? This needs to be done to send correct info to the MMI.
Not forgotten about your messages, just not had time to answer them or arrange a remote session. All you need is the correct coding to be made.Yes, I'm aware about that. Brand new module, parameterised by @DJAlix and shipped to my country.
Cool, cool. Thanks mate. I suppose you are overwhelmed with requests for assistance so I thought I could eventually find someone who had the same problem with TPMS in this forum or maybe in Ross-tech`s so I could solve the mistery myself. Especially because it may be some simple mistake I may have made while coding!Not forgotten about your messages, just not had time to answer them or arrange a remote session. All you need is the correct coding to be made.
