Hi All ,
I’m needing some help with VCDS …….I’m picking up my new S4 Avant on Thursday and would have liked to have swung by the local ‘Audi Specialist’ to have him change a few of the VCDS settings.
Now , he is a good local mechanic , but not a VCDS expert ………so for my previous two cars (S5 and RS4) , I have provided him with the codes.
I need to know from someone if these codes will work on the new B9 S4 so I don’t waste too much time faffing around ….and waste my money with him !! J
Are there any VCDS experts out there who can help me ?
Here’s what I am looking to do ;
Rear LED’s on all the time when DRL’s are on
Removing seat belt chime
Enabling doors locked/alarm armed sound
One Click Remote opening all doors
Adaptive Break Lights
Stop the After-wipe of windscreen wipers when windscreen washer has been used
Auto Release Brake without Seatbelt On
Here are the codes I have used previously ;
REAR LED LIGHTS ON WITH DRL
Removing seat belt chime;
Enabling/disabling doors locked/alarm armed sound:
Just make sure you have the latest VCDS/VAG-COM updates installed and check/uncheck the checkbox Anti-Theft-System:
This may require that factory alarm is installed on the car.
OR
One Click Remote opening all doors ;
• [09 – Cent. Elect.]
• [Coding - 07] -> [Dropdown] -> "x -- 8K1 955 119 -- WWS xxxx" ->
• [Long Coding Helper] -> Byte 1 Bit 3 - 1= Active 0 = Disabled
Auto Release Brake without Seatbelt On;
• This will allow you to move your car and have the brake release without your seatbelt on.
• [53 - Parking Brake]
• [Security Access - 16] (Enter code presented by program)
• [Adaptation - 10] -> Channel 7 change 1 to 0
- ‘Select Control Module’
- Select ‘09 - Cent. Elect.’
- Select ‘Coding – 07’
- Select ‘Long Coding Helper’
- Select Byte 2
- Change Bit 7 to 1
- Instruments 17,
- Coding,
- Long coding helper,
- Seat belt warning active active/inactive
- Horn Confirmation active in 46 Central Conv
- Long Coding,
- Byte 01, Bit 2.
OR
- Module 46
- central convenience
- Coding
- Byte 7
- Tick bit 3 (locking confirmation (horn) via remote control.
- Go to the central locking module and select coding.
- The 'soft. coding' figure in the box needs to be increased by 1024 for beep locks, and another 32 for auto-locks at 15MPH.(i.e. if your figure is 14000, you change it to 15024 for beep, 15056 for beep and auto-lock)
- Make a note of the 'soft. coding' number when you access the module, so you can go back if it goes wrong
- Channel 050: Adaptive Brake Light
- +1 = Emergency Brake Blinking
