Nikon1149
- Joined
- Jan 5, 2017
- Messages
- 3
- Reaction score
- 0
- Points
- 1
Bought my first Audi recently, nice black A3 came with a remap done. I knew there was going to be a few faults as it was cheap and the esp fault light and passenger air bag lights were on. I've already read lots about the esp fault but I'd really like some advice on what the other codes indicate. I'm very frustrated that there are no codes for airbag as the passenger air bag off light is always on.
As well as these two obvious faults there is an electrical buzzing from behind the steering wheel for a few seconds when ignition is first turned, and when right indicator is turned on it buzzes.
After a code clear and rescan the glow plug codes were gone.
All help much appreciated
Saturday,31,December,2016,19:29:56:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ8P07A060381 License Plate: CE56YCO
Mileage: 225970km-140411mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WAUZZZ8P07A060381 Mileage: 225970km-140411miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LS HW: 03G 906 021 LS
Component: R4 1,9L EDC G000SG 8552
Revision: --H05--- Serial number: AUX7Z0F7FNG0PB
Coding: 0000071
Shop #: WSC 00000 256 01574
VCID: 7BF59D8A3A244A9AF5-802F
4 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:54
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101100
Temperature: 72.9°C
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 06314 000 00000
VCID: 73E5B5AA127402DAAD-8027
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047
Component: J255 Klima Man H07 0030
Shop #: WSC 00000 000 00000
VCID: 6DD1A3D27450D42A7B-8039
3 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006070056
Coding: E1885F07A214100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408F2A661342E942E0-8015
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
2 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 225336 km
Time Indication: 0
Date: 2016.12.21
Time: 00:30:00
Freeze Frame:
ON
Voltage: 11.10 V
ON
ON
OFF
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 205
Mileage: 223407 km
Time Indication: 0
Date: 2016.11.30
Time: 00:35:00
Freeze Frame:
ON
Voltage: 11.10 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W0G065A-
Coding: 0071612
VCID: 479D317A366CDE7A21-8013
Subsystem 1 - Serial number: 63328RB40170F7B5O
Subsystem 2 - Serial number: 63428RB40172D582H
Subsystem 3 - Serial number: 63528RB40170F7B6R
Subsystem 4 - Serial number: 63628RB40172D9F0S
Subsystem 5 - Serial number: 63729RB4017D6456P
Subsystem 6 - Serial number: 63829RB4017D1A7BY
No fault code found.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0000042
VCID: 41892F621848E04AEF-8015
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
Component: KOMBIINSTR. VDO H18 0560
Revision: D0H18002 Serial number: 2247F002006207
Coding: 0004418
Shop #: WSC 01234 067 57207
VCID: 3B755D8A7AA48A9AB5-806F
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 157524 km
Time Indication: 0
Date: 2012.03.12
Time: 12:00:21
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 3200106726836F
Coding: 3D0F0B4007000101
VCID: 2E5364DEB9D66F3202-807B
4 Faults Found:
00381 - Databus Instrument Cluster
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 212224 km
Time Indication: 0
Date: 2016.08.24
Time: 12:58:01
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 212224 km
Time Indication: 0
Date: 2016.08.24
Time: 12:58:04
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 199
Mileage: 225027 km
Time Indication: 0
Date: 2016.12.16
Time: 20:43:18
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18002 Serial number: AUX7Z0F7FNG0PB
Shop #: WSC 00444 210 89737
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
Shop #: WSC 06435 000 00000
VCID: 3D71539264B084AA8B-8069
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.078 H07 1806
Shop #: WSC 02069 000 90108
VCID: 35614BB25C805CEA43-8061
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D288505489AC63300
VCID: 3C775E967FAA8DA2BC-8069
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0090
Coding: 0000560
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5163D2B4D0142A3B-8079
End-------------------------(Elapsed Time: 01:42)--------------------------
www.Ross-Tech.com
Coding: 0000071
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:50
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00101100
Temperature: 72.9°C
Bin. Bits: 11111111
P1641 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222214 km
Time Indication: 0
Date: 2016.11.18
Time: 18:18:54
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00101100
Temperature: 72.9°C
(no units): 0.0
Revision: 00H11001
Coding: 0021121
1 Fault Found:
3 Faults Found:
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 225336 km
Time Indication: 0
Date: 2016.12.21
Time: 00:30:00
Freeze Frame:
ON
Voltage: 11.10 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 205
Mileage: 223407 km
Time Indication: 0
Date: 2016.11.30
Time: 00:35:00
Freeze Frame:
ON
Voltage: 11.10 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0000042
Coding: 0004418
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 157524 km
Time Indication: 0
Date: 2012.03.12
Time: 12:00:21
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Time Indication: 15
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 212224 km
Time Indication: 0
Date: 2016.08.24
Time: 12:58:01
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 212224 km
Time Indication: 0
Date: 2016.08.24
Time: 12:58:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 199
Mileage: 225027 km
Time Indication: 0
Date: 2016.12.16
Time: 20:43:18
Coding: 0000048
1 Fault Found:
Coding: 0000560
2 Faults Found:
Address 56: Radio
Cannot be reached
