- Joined
- Dec 13, 2014
- Messages
- 2,960
- Solutions
- 1
- Reaction score
- 858
- Points
- 113
Would someone be so kind if they ever happen to scan/adapt anything on a MY17 S3 make a note of which controllers there are label files for? It's just that I can't scan or adapt this car all the time as I don't own it but would like to be aware of future tweaks as they become available.
More so in particular controllers; 02,03,10,19, 47, 55, 5F, BB & BC?
I took this autoscan last night and didn't realise RT had released a new version of VCDS until this morning.
Maybe @DJAlix ?
Much appreciated
Maybe @DJAlix ?
Much appreciated
Code:
Friday,06,January,2017,19:21:41:49196
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: xxxxxxxxxxxxxx License Plate: S3
Mileage: 86km-53mi Repair Order:
Chassis Type: 8V (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 47 52 55 5F A9 BB BC
VIN: xxxxxxxxxxxxxx Mileage: 86km-53miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DJHA) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A2500122426010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
ROD: N/A
VCID: 479923D2FE6DD87A48-8012
No ASAM data for: "EV_ECM20TFS0208V0906259J" (AU37)
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 300 011 M HW: 0GC 927 711 G
Component: GSG DQ381 H06 0704
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001
ROD: N/A
VCID: 2C537C7E47CB1B2245-8078
No ASAM data for: "EV_TCMDQ381061" (AU37)
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 62966000000027
Coding: 329C938D54A01BAC89980B6C419A694CC92AD891D082967602415074820812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 397D552AB899BE8ACE-806C
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001065224
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 408B38CEDB43EF4289-8014
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor 4H0907658B or0MUFU03 0005
Serial number: CA58C65800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001628906385
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF78636E13759B2BB-802A
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160726 043 0580
Serial number: 160803201824
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62395966
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 23 08 2016 00000400
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY162580YY3
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000067455380
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 5QA 919 283 A HW: 5QA 919 283
Component: PDC 4 KanalH07 0038
Serial number: 000308419616272
Coding: 0600040011
ASAM Dataset: EV_EPHVA14AU3700000 009029
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 489B20EEF373D70241-801C
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR28W3D1
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 102BC88ECBA35FC259-8044
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 810 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000F911DAE1-
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 810 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000C6875DE1$
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 610 16
Component: SideSensor_Dr 000 6149
Serial number: 35100019F22BF35325D9
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 610 16
Component: SideSensor_Pr 000 6149
Serial number: 35200019D2290BB4B300
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 402 209 16
Component: FrontSensor_D 001 6149
Serial number: 3550002C12076364B27X
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 403 009 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001992303C92B33-
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 403 009 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001992303C94F3B8
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 002 109 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000240B04E1X
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 002 109 16
Component: PedPSensor_P2 001 0887
Serial number: I0N0000000076B4D5E1G
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 HB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 24101604400404
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 010DFDCA90C9264AC6-8054
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 972 Q HW: 8V0 920 972 Q
Component: KOMBI H04 8316
Coding: 27AD080A2B8026000101EE001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
VCID: 4C931CFEE70B3B2265-8018
2 Faults Found:
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 28 km
Date: 2017.01.06
Time: 16:37:38
13639427 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 46
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005512046
Coding: 030100043F085A005B0082683C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013020
ROD: N/A
VCID: 2F696B7276DD603A60-807A
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20161012091809 20463
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001610196577
No ASAM data for: "EV_GatewNF" (AU37)
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00027.09.16
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 458529DAC461CA6ABA-8010
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 131016EJD20761
Coding: 005D8A204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 438137C2CA55F45A94-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A7F4A26BD9FB592C7-806E
Address 47: Sound System (J525) Labels: None
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX00BRHY
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: N/A
VCID: 62CFD246758F9D52BF-8036
No ASAM data for: "EV_AMPMst16C9Gen2ALPI" (AU37)
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 171016EJF23698
Coding: 005D82204401040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428F32C6D54FFD529F-8016
Address 55: Headlight Range (J745) Labels: None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Revision: -------- Serial number: --------------
Coding: 0EEE00102B230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
VCID: 3E774636A1B799B2FB-806A
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 81A 035 192 B HW: 81A 035 192
Component: MU-HS-LND-EU 045 0170
Serial number:
Coding: 017353010000000011111102000A00102F002BE601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 204B984E3B03CF42E9-8074
Data medium:
Subsystem 1 - Part No SW: 8W0 919 866 M HW: -----------
Component: ECE 2017 --- 0024
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2088SX
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL105091600010473
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160912201569
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 101016EJA0268C
Coding: 000C82204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 101016EJA02685
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End---------------------(Elapsed Time: 04:21, Deb=2)-----------------------
