Saturday,22,October,2016,10:27:33:06047
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8K8FA123456 License Plate: 4UDI
Mileage: 25510km-15851mi Repair Order:
Chassis Type: 8K (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
AC
VIN: WAUZZZ8K8FA123456 Mileage: 25510km-15851miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CSUA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 CA HW: 04L 907 309
Component: R4 2,0L EDC H23 8466
Revision: 85H23---
Coding: 12034012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01104L906021CA 002007
ROD: EV_ECM20TDI01104L906021BG_002.rod
VCID: 66C5DA1A9970527226-8032
1 Fault Found:
4531 - Fan 1 Control Circuit
P0691 00 [032] - Short to GND
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 25372 km
Date: 2016.10.21
Time: 16:47:31
Engine speed: 895.50 /min
Normed load value: 77.6 %
Vehicle speed: 2 km/h
Coolant temperature: 25 °C
Intake air temperature: 24 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.900 V
Unlearning counter according OBD: 40
Air mass: specified value: 250.0 mg/stroke
Coolant temp. sensor 1 bank 1 at cylinder head: raw value: 2222.0 °C
Heat delivery temperature in cooling system: -273.1 °C
Extern.temp.sens.1 bank 1: raw value: 12.5 °C
Coolant fan 1: activation: 10.20 %
Fuel temp. sensor 1 bank 1: raw value: 14.6 °C
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K5 927 155 B HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H08 0002
Revision: --H08--- Serial number: 0000000766
Coding: 000002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02433
ROD: EV_TCMVL381_AU57.rod
VCID: 377B475E8E5A1BFA4D-8062
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CN HW: 8K0 907 379 CN
Component: ESP8 front H09 0020
Revision: -------- Serial number: --------------
Coding: 3D1DCC01
VCID: 071BF79EB63AAB7AFD-8052
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Revision: 00002001
Coding: 01B24040000000000000
VCID: 7F0B6F7EEEEAE3BAC5-802A
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0815000100739018
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 3215000149757013
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K2 820 043 BB HW: 8K2 820 043 BB
Component: KLIMA 3 ZONEN H04 0122
Revision: D1000000 Serial number: 01110920150742
Coding: 342400A000
VCID: 6ADDAE2A8568761202-803E
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001160230201
Coding: 260000108034AFC00081400300001D0D001D470827090201000008004400020100000024000000
VCID: 78F98462CBC4D48284-802C
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290815 H06 0080
Serial number: SWF15088295254
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20618593
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000409156242
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: DD4846C7000000000001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H49 0610
Serial number: 003KFDD1HP2N
Coding: 30534435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489934A2F3A4640234-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME535B50709
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME5419364EK
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME14511E407
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME72512B74H
Crash sensor for front airbag: driver side:
Serial number: 63732SME02534350L
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME0253396E%
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OI5000SH
Coding: 000037
VCID: 489934A2FBA4640234-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 G HW: 8K0 920 983 G
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 61+51KX8G
Coding: 33A6100003012600010000
VCID: 397F4166B04E0D8ABB-806C
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 25305 km
Time Indication: 0
Date: 2016.09.14
Time: 10:03:23
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 T HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0070
Revision: 1Y090032 Serial number: 3241Y1580600D6
Coding: 80CF07FF00
VCID: 50A91CC203F4ACC26C-8004
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 5343917603
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 15242000286011200181
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0511
Revision: Serial number: 0000164879702
Coding: 011002204001410001
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0008119529
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E75527AA1602AB28E-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0373694406
Coding: 013B0622A0B930008320023680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0511
Revision: Serial number: 0000164890167
VCID: 4FAB1FBE1ECAB33A75-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001713807
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 3A7D5E6ABD480692B2-806E
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109I 0F2502658
Coding: 010103020100000001
VCID: 2B536B2E4A12AF1A39-807E
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 J HW: 8R2 035 666 H
Component: H-BN-EU H49 0941
Revision: -------- Serial number: 515I10F7551582
Coding: 0F0101010006A1ED01808B5E00000403E40000020000000000
VCID: 40892C82D3945C42FC-8014
Subsystem 1 - Part No: 8R0 060 884 CR
Component: EUR 2015 2102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130IW0F3454651
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000002365291
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 6208
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000166449155
Coding: 010002204001210001
VCID: 46853A9AF1B07272C6-8012
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 C HW: 8K9 827 851 C
Component: J605 Master H56 0330
Revision: -------- Serial number: 8K9827851C
VCID: 3E75527AA9602AB28E-806A
Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C
Component: J756 Slave H56 0330
Serial number: 8K9827852C
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000166449159
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152171086
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
VCID: 2F6B7F3E760AD33A15-807A
End-------------------------(Elapsed Time: 03:50)--------------------------
Address 17: Instruments Labels: 8T0-920-xxx-17.clb
Control Module Part Number: 8K0 920 983 G HW: 8K0 920 983 G
Component and/or Version: KOMBIINSTR. H35 0567
Software Coding: 33A6100003012600010000
Work Shop Code: WSC 06325 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 25305 km
Time Indication: 0
Date: 2016.09.14
Time: 10:03:23
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 25305 km
Time Indication: 0
Date: 2016.09.14
Time: 10:03:23
Address 09,8K0 907 063 DH,channel 34,adapted from,28,to,24,
Address 46,8K0 907 064 KG,channel 60,adapted from,15,to,00,
Address 09,8K0 907 063 DH,recoded (Long Coding),from,260000108034AFC00081400300001D0D001D470827090201000008004400020100000024000000,to,260000108134AFC00081400300001D0D001D470827090201000008004400020100000024000000,(06325/000/00000),
Address 09,8K0 907 063 DH,recoded (Long Coding),from,260000108134AFC00081400300001D0D001D470827090201000008004400020100000024000000,to,260800108134AFC00081400300001D0D001D470827090201000008004400020100000024000000,(06325/123/12345),
Address 09,8K0 907 063 DH,channel 6,adapted from,1500,to,500,
Address 09,8K0 907 063 DH,channel 26,adapted from,8,to,18,
Address 46,8K0 907 064 KG,recoded (Long Coding),from,013B0622A0B930008320023680000047,to,013F0622A0B930008320023680000047,(06325/000/00000),
