Polisher. DS or rotary?
Ben85
Age
39
Suffolk
I've been looking a machine polishers. Is there much difference in finished between a DS and a normal rotary one? I know the DS is a little safer for not burning through the paint.
Agree with @Bristle Hound DA. Even professional detailers use them. With a Rotary and you're not experienced you could burn the paint. DAs head osolates therefore no damage done. I've had mine for 5 years or so and wouldn't be without it.
Just remember, if you're taking out swirls or scratches use the least abrasive pad and compound combo to get the job done.
Reactions: Ben85
i use a da, always start with a soft/medium pad and compound, if it doesn't work, step it up!
Reactions: Ben85
Personally I use a Rotary T 1500 rpm and get amazing results. I think it's personal preference and an ability to learn. DAs are safer, and yes give you an introduction to machine polishing, but a Rotary gives better results. As long as you do your research, take things slow, listen to what the professionals say, anyone can use a Rotary. So many people are put off my scaremongering when it comes to a rotary.
Reactions: Ben85
Incorrectly used you can burn through the paint with any polisher................
Reactions: Liber_A4_te
Seen the dodo juice DAS-6. Only going to be using it on my cars so think it should do the job.
Ive got one and its great... perfect for a first machine...easy to use....good comfort whilst using it!
Although i use chemical guys hex logic pads !
Reactions: Ben85
I've got both, a good DA is a great machine and definitely a bit safer as it won't generate as much heat.
Probably safe to say with the rotary you need a bit more experience and I wouldn't recommend using one on
Plastics such as bumpers because of the heat issue.
Reactions: Ben85
