Tire pressure light flicker help
CraigGB
A4 B7 2.0 Tfsi 2007
Age
42
Hinckley
good evening everyone I need help with my A4 B7. I fitted a dis stalk and earthed the cable from pin 1 of the blue connector that goes into the instrument cluster (apparently to stop the washer level warning) and coded it using vcds and an online guide. The dis works fine but since doing it the tpms warning light is now flickering in no particular pattern!
Does anyone have any suggestions?
Thank you in advance, Craig
now fixed it was the coding in adaption 19, i had to change it to not look for remote clock or lap timer.
