Footwell light's upgrade
KrisKrk
A6 C6 4F 2010 LeMans Avant
London
Wanted to brighten up Ambient lighting and thought of brilliant idea.
Had a 5 metre reel with 12V crisp white leds lying around so decided to stuck some of them into the footwell lamps and see if they work.
Leds are divided into sections of three so cut out one section, stripped connectors (waterproof strip), add some solder and aligned with original led circuit
Solder on top of original led
Secured with shrink tube
Fitted into the clear plastic
And closed it up
Here's the result
I'll take some night time pictures but it is much brighter now and still can adjust it
Reactions: Misikee, Steveredman and Roadrunner146
Will install these leds later on into door Ambient lighting across the whole section.
How easy is it to solder
Reactions: KrisKrk
Solder is like solder. Tine up terminals, solder hem on to the prongs and job done.
Looking at it now, it was a proper cowboy job. LOL
It did worked though so cannot complaint.
Upgraded it not long after anyway
Sent from my Huawei P30 Pro using Tapatalk
That’s nice where about you based you want to do it for me lol I have never done it before
I'm near Heathrow, London.
Got all of them upgraded lights from Aliexpress and they are super bright
Reactions: Stuaboy
I have never soldered before that’s the only thing
Do you know what size bulbs are
Did this in my S5 - got the bulbs from Rocket Wires— really bright and dimable too.
1E161D9E 0DC4 49B6 8EA5 B42AE4C28E12
9B58640E 72F2 41B8 AAEF 04009BDC685B
B26838BF 6708 44B4 90D0 4E41D55F6B8D
Before and after pics below
I like them are they just straight swap
Yep straight swap. just popped the lens cover , unclipped the led board (bulb) and replaced with the new one. Then popped it all back in.
The ones in the pics only took a couple of mins to swap. The only issue I had was doing the ones for the rear the passenger footwells. My S5 is a coupe so getting access under the bottom at the back of the front seats was tight (understatement) to begin with and the wiring harness is only just long enough to pop the lamp holders out. Needed to be a contortionist to get them back in and ended up cricking my neck In process
if it’s a saloon then the rear passenger footwells should be a lot easier
Are the q3 the same for bulbs as I have a q3 2012
NHN
NHN
672
