Hi I have an a4 b7 tfsi quattro. I have fitted wiper with dis and that works OK but I cannot get the cruise control set up. When I go to engine in vcds the config 11 is greyed out. If I try to change the setting using the long code it says it's done but when I check it has still got the original numbers. I have looked for hours on different sites but can't find an answer. The vcds is from eBay but everything else session to work.
