hey guys, i've been having a problem with my left headlamp (facelift bixenon with AFS)
when turning on the car, the left headlamp has been taking like a second longer to light up.
and that was a little weird, so i turned off the car, and just did contact, and the headlamp did not light up.
of course the bulb out warning on the cluster came out, but then i turned the car on, and the light was up again (but the MIL stayed on).
after several tries, the problem still the same, it says the bulb is out, but it lights up (on both low and high beams).
here is the scan.
i dont know if its the problem will be with the ballast or the bulb
Tuesday,01,October,2013,12:20:47:40973
VCDS Version: Release 12.12.0
Address 09: Cent. Elect. Labels: 8P0-907-063.clb
Control Module Part Number: 8P0 907 063 N HW: 8P0 907 063 N
Component and/or Version: BCM PQ35 M 110 0653
Software Coding: 4E000A2FA807F200207241E00100094C427E8DAA306DD928E40008840040
Work Shop Code: WSC 61503 615 104880
VCID: 3F8DA57EAEDDB1E6AD9-806A
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 5
Reset counter: 34
Mileage: 61376 km
Time Indication: 0
Date: 2017.04.15
Time: 17:24:52
Freeze Frame:
Term 15 On
Voltage: 11.60 V
ON
ON
Term 50 Off
OFF
OFF
here is the scan.
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 34
Mileage: 61376 km
Time Indication: 0
Date: 2017.04.15
Time: 17:24:52
Freeze Frame:
Term 15 On
Voltage: 11.60 V
ON
ON
Term 50 Off
OFF
OFF
