Help understanding a couple of symptoms
JuanPablo
Hi all,
Wondering if you can help diagnose a problem/point me in the right direction.
Recently I've noticed a couple of issues with my B6 A4 1.8T (190ps) which may/may not be related:
My engine has started making a whining noise upon start up, it's idling slightly higher than usual too (1200RPM rather than ~800) - this stops after a few minutes and the car idles normally. I've narrowed this down to a potential secondary air pump issue but as yet I've been unable to have a proper look/scan for fault codes.
Today, when coasting up to a roundabout in 3rd, I went to put the power down and nothing, pedal to the floor 3 or 4 times (with no engine noise) before eventually it came back to life.
I've noticed this problem a couple of times over the last week, usually when accelerating in lower gears. On the whole she's driving normally but I'd like to know what I'm potentially looking at.
As I say, I've been unable to scan but I've asked around for anyone in the Nottingham area with a VAGCOM/VCDS, failing that I'll buy a lead & have a look myself.
Update for JP's issue, we scanned his car, cleared all faults and then we took it for a spirited drive and then did a second scan. No persistent engine faults logged, so I guess he'll have to see how it drives for the moment, the car drove smoothly with no hesitation at all during our tests.
Initial scan:
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No SW: 8E0 909 518 AS HW: 8E0 909 018 A
Component: 1.8L R4/5VT 0003
Coding: 0011511
Shop #: WSC 00000 000 08192
VCID: 0103AFBA5B1B2B3671-5140
2 Faults Found:
17701 - Map Controlled Engine Cooling Thermostat (F265)
P1293 - 001 - Short to Plus - Intermittent
19534 - Throttle Control
P3078 - 002 - Airflow at Idle too Low
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04475
Shop #: WSC 06435
VCID: 65CB9B2AFF73E716ED-5124
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63351
VCID: 60C58A3EE051823E1E-5124
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 06435
VCID: 356B0B6A0F5357969D-4B06
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3E7914466A6594CE4C-5140
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01011
Shop #: WSC 63351
VCID: 438F65B25187F92623-4B06
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 N
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 19411
VCID: 346D366E04294E9EAA-5140
WAUZZZ8E05A037159 AUZ6Z0D0214778
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: 6BDFED121997D166BB-515E
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BD
Component: Komfortgerát TBF 1712
Coding: 06891
Shop #: WSC 00720
VCID: 74EDF66E44A90E9E6A-4B06
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01332 - Door Control Module; Passenger Side (J387)
53-10 - Supply Voltage Too Low - Intermittent
01560 - Passenger Door
61-10 - Won't De-Safe - Intermittent
End-------------------------(Elapsed Time: 06:23)--------------------------
Second scan after clearing faults and taking the car out for a spirited drive:
Coding: 0011511
VCID: 0103AFBA5B1B2B3671-5124
Readiness: 0010 1101
Coding: 04475
Shop #: WSC 06435
VCID: 65CB9B2AFF73E716ED-5106
Coding: 00000
Shop #: WSC 63351
VCID: 60C58A3EE051823E1E-5140
1 Fault Found:
Coding: 00001
Shop #: WSC 06435
Coding: 0010602
Coding: 01011
Shop #: WSC 63351
Coding: 00401
Shop #: WSC 19411
VCID: 346D366E04294E9EAA-5124
1 Fault Found:
01304 - Radio
Coding: 00001
Shop #: WSC 00000
Coding: 06891
Shop #: WSC 00720
VCID: 74EDF66E44A90E9E6A-4B20
End-------------------------(Elapsed Time: 06:21)--------------------------
Thanks Franko, good to meet and chat.
I'll keep an eye on it, piece of mind at least with no persistent faults!
I'll update as/when
So we'll have to see if the car hesitates again and if the faults below re-occur. Thermostat might be on it's way out, would be worth observing if the needle on the temp gauge on the instrument cluster sometimes drops down even when the car is warmed up. The throttle control fault could be to do with a loose or perished hose going to the throttle body, so it's worth inspecting that area.
Does the car idle okay once warmed up? I was thinking about the PCV valve, this causes problems with the fuelling.
The whining noise is usually the SAIP pump failing due to water ingress, rpm will be approx 1200 for around a minute or two, this is the SAIP system and is for warming the cat up quickly to clean up cold start emissions. It pumps filtered air into the exhaust manifold to heat up the cat really quickly.
Reactions: fanta
Hi QuatroCalum,
Car idles fine after about 5-10 mins (depending on how cold it is/long it's been sat) - I think you're right, the SAIP is probably the culprit, do you think it's worth replacing/repairing that first & then changing the PCV valve if no change?
Edit: As a point of note, I did a run to Southampton & back over the weekend (350 mile round trip) & there was no re-occurrence of the loss in power mentioned previously.
As others have said the initial noise is the SAI (secondary air intake) pump.. It pumps air into the cat to clear it from carbon. When it's on its way out it whines and sounds bad.
Second issue is most definitely pcv related.. If you've never replaced the valve that's under/beside the coolant tank then it will only help.. I forked out for the 034 one but the oem one is fine.
Sent from my XT1572 using Tapatalk
