Northampton_ofn
- Joined
- Jul 21, 2015
- Messages
- 297
- Reaction score
- 102
- Points
- 43
- Age
- 35
Right guys I need some help. I've substantially upped the power on my 1.8t with a K04 hybrid. I haven't even remapped yet and i've started getting ridiculous clutch slip. At every stage with this car i've uprated when something has failed, and that's what I want to do here.
I want to fit a 6 speed box, partly because I want 6 gears but also because the flywheel is larger which paired with a performance clutch will result in a setup much more capable of dealing with the additional torque.
My long term plan is to fit a quattro setup (all the 'buy a quattro then' haters feel free to leave) so my question is, can I fit a quattro 6 speed box and some how disable/block off/not link up the rear drive prop shaft?
If not possible, I at least don't want to spend a load of money on a clutch to then replace it later, so does anyone know if a six speed FWD box uses the same clutch as the quattro box?
Anything else I'll need? Are there different subframes or just mounts?
