I've not got an iPod Shuffle, but I've got a 2nd gen iPod Touch (around 6+ years old) that I've managed to hook up to my S3 using USB. I originally didn't think it was going to work as it took a good 10 minutes to connect up, don't know whether it was just syncing or what.
Only slight issue I've had is sometimes it just says connecting for ages but usually when I start the car when it usually starts playing instantly, fairly simple fix with just unplugging the USB and replugging.
+1 on the SD card I have 128Gb one for music and a 64Gb one for videos.
Or perfect Father's day present the latest gen shuffle/ipod.
Another thought, you may struggle to get the Album artwork with the Ipod. Bit nerdy I know but I need to see the artwork!
I'll be surprised if an aux lead will allow you to change tracks, pause etc through the steering wheel controls. SD Card.... you know it makes sense
You're right about the wheel controls so I may have to return it, it's a pita keep changing it on the iPod! I take it with an SD card you can use the steering wheel controls?
Yep S/W works perfect it scrolls through album art faster, has better search functionality and starts where you left off - compared to my iPod classic.
Cool, cheers Rob. Looks like I'll be returning the lead and getting a card then, thought I'd give it a go as I've got the iPod already just sitting there.
^^ Good advice, don't go cheap on the SD card. Cheap cards may have equivalent capacity but the access rate is slower which in extreme cases could cause music drop outs. Go for a class 10 card.
I convert music into variable rate WMA files. Its a good compromise between music quality and file size.
Should work using the aux port in the centre armrest. I've got my old iPod classic plugged in there (using the white Apple cable) and it works well.
........and starts where you left off - compared to my iPod classic.
At last Rob, someone who's acknowledged the problem I referred to in my penultimate post above.
Is that issue exclusively related to the set up I'm running then?
PS sorry for hijacking your thread @Tom.H
I switch to a song with the wheel on the centre console and click it down to accept... it doesn't accept... so have to use the steering controls. grrr... stoopid Audi lol (note, it's probably me)
I get that too, or you select one track and it chooses a completely different one, plus the sound quality isn't as good via Bluetooth.
Do the tech versions of the A3 have more steering wheel controls? I only have the volume control and the programmable * button (which I have programmed to next track)
I can't scroll and select (I don't think). Or does the wheel on the left side of the steering wheel do that? I've never actually looked, and will do, now that folks suggest scrolling and selecting on the steering wheel.
