hi all,
been having some issues with my car and starting and running. I had a local member run vagcom on it and cleared faults and replaced a few parts.
The car started and ran for about 20 mins then shut down, it would then start but only run for a few mins with it then deciding not to run again. The pump in the tank has been replaced and also the hpfp , so maybe one of these are faulty? I would also note that when the car was running the pump in the boot was constantly running.
Below is the fault that vagcom picked up :-
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 8E0 910 401 K HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G200SG 0040
Revision: --H01--- Serial number:
Coding: 0011111
1 Fault Found:
004501 - Fuel Pressure Regulator Valve (N276)
P1195 - 001 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.63 V
Pressure: 0.0 bar
Duty Cycle: 50.1 %
Readiness: 0 0 0 1 1
Any help would be appreciated
Coding: 0011111
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.63 V
Pressure: 0.0 bar
Duty Cycle: 50.1 %
