What parts do I need for a service
johnlondonw3
Im going to buy the parts for the service and have an independent fit them,what do I need ?
Cars an A4 Avant tdi sport on 46,0000 miles
I'm also going to get the cambelt changed,do I need to get a new water pump fitted at the same time ? Anything else I should get fitted or changed when doing the cambelt/service ?
John:beerchug:
Cambelt kit (from GSF comprises belt, idler pulley and tensioner)
Waterpump
Auxilliary drive belt
G12 coolant (2 bottles)
Oil air fuel and pollen filter
Engine oil
Sump plug (just in case)
Wiper blades
Brake linings (if they are worn out)
You should also think about changing the brake fluid.
If you are doing the water pump , and going to GSF make sure you get the metal impella`d water pump
They are about the same price as the plastic ones and will last longer
If you go to a dealer , they only supply plastic
Sarah
864
9
908
9
791
