- Joined
- Oct 14, 2009
- Messages
- 4,768
- Reaction score
- 1,008
- Points
- 113
- Age
- 59
- Location
- Kilwinning Ayrshire
My mechanic told me to not use the Halfords stuff unless I water it down as it leaves a horrible residue which then blocks the nozzles on the sprayers.Mine work fine and do a better job that the 3 jet ones , its just the fan is to wide and catches the trailing edge of the bonnet. silly problem, maybe cured with a change of screen wash brand. dont know whats in the halfords stuff but it sets like a sticky treacle...
Booked in for a Haldex service Friday up at CM Tuning as I stupidly went on milage instead of years and it hasn't been done since 2014.. ( it may have been throwing a Haldex pump code and causing Haldex not to engage)
If it’s throwing the pump code it’s probably gunged up and will most likely need changing unless it gets cleaned out, they won’t normally do that as part of a service, also make sure they change the filter as Audi garages don’t change that either
dsg farts
Decat downpipe, boosts better and louder dsg farts
Nope stock dsg will do it on hard accel. Causal diving maybe but more quite ways to make it louder but no obnoxious is a mid silencer delete on the exhaust and aswell as an intake as it made mine louder then it was with stock intake system.Please enlighten me on DSG Farts, I am new to the DSG - S-Tronic world.
Does it have to be a decat and petrol to get the farts?
Probably had alot of boost leak revive the performance and hold boost betterWhat is different now?
Retrofitted the OEM Bluetooth phone module to work with my Symphony 2+. Much easier than I thought it was going to be, took about 2 hours from start to finish. Thanks to @s8craig and vag_retrofits for the help and the advice. £89 from eBay with a new mic and a plug and play wiring harness.
Does that allow music to be played through Bluetooth or just phone calls?
My next (and probably last) retrofit on my A3 8P. Front parking sensors with OPS to integrate with the R8 rear view camera.
Have you got part numbers/link to the parts mate? And how easy did it go together?
It’s something I really want on my S3
Petrol yes decat no dont think they made diesel dsgs anyway diesel will have standard auto box could be wrong thoughPlease enlighten me on DSG Farts, I am new to the DSG - S-Tronic world.
Sent from my SM-N960F using Tapatalk
No i meant the actual burps you get when changing gears, didn't know they made diesel dsgs that's good , but yea you do get the crackles and pops with a petrolI got a diesel DSG, and I guess when you say farts you refer to the pops you get from petrol engines.
Ashtray delete and then installed ambient LED for the cubbyhole.
Mine does the same thing since I put on new tires 2 summers ago. Two different alignment later it still does it, mostly noticeable on roads with a lot of camber. I've been told it could be tire conicity. My mechanic haven't found anything wrong suspension wise do I believe it could simply that. Haven't bothered to fight for tire replacement...Hi everyone,
I've been coming and going to the mechanic two weeks now as my ride went in for a set of rubber as they were shot. Four new tyres and an alignment later gave me a car that did go to the left if I let the steering wheel unattended; went to another mechanic whom told me last tracking was out of parameters, and car still doesn't want to go as it should, even though mechanic says it's on parameters.
Also had some lighting issues still waiting to be adressed (xenon lights are pain in the ***)
I'm willing to paint the grill satin black as I'll need to take apart the bumper for the bulb swap.
Nice rides I'm seeing here!! keep the good work pals
