Hi where did you get that from mate
Fitted a non smokers pack cigarette lighter replacement. Looks so much better now!
Thanks gonna have a look .From someone breaking an A3 on Shpock for £20. You can get it brand new from Audi for about £35 I think. The part number is 8P0 863 387 A 6PS
Hi mate possible wrong part no it comes up as a cig lighterFrom someone breaking an A3 on Shpock for £20. You can get it brand new from Audi for about £35 I think. The part number is 8P0 863 387 A 6PS
how u gonna charge phone now ?
I was watching this some time but realized airbag shape is different won't fit mine from A3 .. it is best buy it all together from ebay audi cars - breaking breaking
Bought a flat bottom steering wheel too. Need to find an airbag now (and reasonably priced too!).
Thanks mate notice it was a flip lid. Will check it out@leonwilliams - it’s the correct part - it is a cig lighter! Mine was £25 inc vat and postage from Audi - contact mjr901 on FB Messenger. He’s an Audi Main a Dealer parts specialist.
I don't have any other in my carPlug the charger in to the lighter socket, under the flap!
Guys
How is radio antenna wire running through the car ? I am losing signal when I accelerate and when I break signal come better .. sometimes ..
That means antenna is moving somewhere and is loose ..
Cause you’re going faster than the speed of sound.
What a BelterPlug the charger in to the lighter socket, under the flap!
Looking good , but am sure those alloys are sticking out a mm or 2Airtec Stg2 IC
H&R ARBs front & rear
Yellow Speed Racing 356/6pot big brake kit
12mm ST hub centric spacers all round.
View attachment 151479 View attachment 151480
U true ******* joker right ...Cause you’re going faster than the speed of sound.
Not bad at all!fitted flush parking sensors from aliexpress. came prepainted, not bad for £17
View attachment 151223 View attachment 151224 View attachment 151225
Not bad at all!
Got a link mate?
Also are they wired straight to reverse lights?
https://www.aliexpress.com/item/13m...ckup-Radar-Buzzer-System-For/32792594571.html
yeah,
this video was useful (if only for trim removal and wiring). i used a 12v lamp tester to confirm which wire was the reverse, and its the same as that vid, blue/red.
if youve got a sportback, it might be slightly different as the reverse is in the tailgate, so youd have to test to confirm the wire, then trace it back up the loom inside the car to tap into, but shouldnt be too hard.
only 'negative' id say is compared to the factory sensors on my last car, id say they are a few milliseconds off. but for the price its a minor tradeoff.
H&R springs and TTRS top mounts gone in. Now the wheels look lost in the arches . Who knows what thickness spacers you can use with standard wheel bolts?
What spacers did you go for? I’ve seen a few different brands, surely they are all more or less the same?With standard bolts you’re limited - don’t go any more than 3mm.
I’ve just had 12.5mm added all round and I think they’re a little too wide.
Great write up and video!
The one thing i think cant beat factory sensors is the beep tone!
picked up some metal pedals today. Do they need coding?? Mate of mine seems to think they do.Sent from my SM-G935F using Tapatalk
Sweet. this guy had a couple of sets.No, plug & play
