Beep when locking car
KEF A3 20V T
Turbo's Rule
Whitby
Hi i have recently coded a remote flip key into my 1998 A3 t sport, and i was londering if any1 knows what the soft code changes are to enable the locking over 15mph and beeping the al;arm when locking etc! also how the whole softcode changing thingy works! cherers kef
Hi mate,try this site.This was what i used to recode mine.I found the door auto lock to be rather annoying and took it back off.
www.wak-tt.com
Then go into the tt info,then to vagcom coding scroll down from there and you will come across central locking.hope this helps
[Select] -> [35-Cent.Locks] -> [Coding] (or [Recode] on older versions)
To enable Auto-Lock: add 32 to your existing Coding.
To enable the beep when locking: add 1024 to your existing coding. This only works if your car was equipped with a factory alarm system.
-Uwe-
