Macintosh88
- Joined
- Jul 21, 2017
- Messages
- 86
- Reaction score
- 77
- Points
- 18
Have a play on this site, you'll have to enter your intended wheel and tyre sizes:
http://www.willtheyfit.com/
Ok, I was also nitious with a measure of the car but I think the wheels are a bit too far in. As long as it does not affect the car handling and mechanical parts.I don't like moving away from wheels actually recommended for whatever car I've got, I'm pretty sure its ET49 on the FL RS3, so ET42 is IMHO no go........
4x front R8 rims will work fine
Mine has 8.5J, ET 43 wheels on and the poke out is bang on. See pic:
Mine are HRE FF01's. Actual wheel ET is 47 with 4mm spacers to make the poke out perfect. The wheels needed to spacers to clear the front caliper.
No real difference in handling, as the tyres are the standard size 235/35's, and the extra width of the HRE wheel means the bulk of the tyre still sits mainly in the original footprint. These wheels are much lighter than the OEM ones too.
I also confirm you are OK. I have ET41 that are fine. Also no difference in handling (on road conditions anyway..) and the self centering steering is still very positive.
Thanks for your all reply and confirmation that works
So I need to be careful to the front caliper so it doesn´t hit the rims.
Why would they..?So I need to be careful to the front caliper so it doesn´t hit the rims.
Why would they..?
Apologies - I was not asking the question for a technical answer - it was a poor attempt by me saying: if they fit an R8, they are sure to fit an RS3..!
I fitted 4 of these R8 front wheels to my TT RS Mark 3 (the new one) and there is lots of clearance. Should be fine on an RS3. You have the widths wrong on the willtheyfit graphic above. On the TT there is only a 3mm outer difference on an ET52 standard rim on the TT.
Ahh ok, yes I see now, it´s 8,5J not 9J on R8 front rim.
Did you buy 4 fronts from ebay? Most of them only sell in set or just one rim. Maybe I can ask the seller just buy 4 front rim
@Macintosh88 - Do watch out for genuine wheel rims, I'm sure as a car guy you must already be aware of poor quality copies and the consequences of using those.......... Honestly don't mean to be putting a dampner on your enthusiasm for your mod, but wanted to give you the heads up.
