Dis and cruise help!!!
Jamie1087
Swansea
Hi all, I have installed cruise and dis, had them coded , car accepted codes but for some reason they are not working.
Any help will be much appreciated, will post up the vag code errors when I get them sent to me
Ok so you're missing some information here. What is the part number of your SWCM?
I didn't do the coding (and have no idea how to) so what info is required? And as for part number I don't know the number, I bought the parts off a breaker and it said it was off an A4 b7 avant
Get someone on it that knows what they're doing, no offense.
Whereabouts are you located?
Reactions: Darren92
Ok not close to be lol, I have a job next week in Bromsgrove if you can get to there Friday/weekend.
If the car accepted the coding it's because the module is correct..
Beyyer look at clutch switch because if this is faulty cruise control won't work either..
Sent from my SM-G935F using Tapatalk
Reactions: Jamie1087
My module only accepted the code when I got the new one.
I tried the cc code on module that wouldn't support it and car simply didn't take it..
These are the error codes,
Saturday,26,August,2017,14:34:54:55632
VCDS Version: Release 17.8.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
LR Enginering
Address 01: Engine Labels: 03G-906-016-BLB.clb
Control Module Part Number: 03G 906 016 JD HW: 028 101 265 4
Component and/or Version: R4 2,0L EDC G000SG 9643
Software Coding: 0000072
Work Shop Code: WSC 66565 257 00032
VCID: 6ED32F88794E553668-803A
2 Faults Found:
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 255
Mileage: 178147 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 178147 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
All sorted not, massive thanks to tezgreig!! He sorted everything out
Reactions: Wayne p
How did you sort this ? I've just fitted dis stalk and activated it ,, instantly low screen wash illuminated but buttons on stalk do nothing!! Thanks
You have to take off the clocks, and splice into pin 1 from the blue plug out of the back and ground it ( it should be the brown and red wire. The washer bottle function won't work then but ist tricks the computer in to thinking the sensor is active, but it's not. If the pin is not the ( as on some models it's not,) you need to but the wiring kit then ground it
Reactions: Wayne p
So once it's been grounded the functions on the stalk will work ? Thanks
Do I do pin 1 in the green plug or blue ?? Very hard to identify which is pin 1 also ? Thanks
Blue plug.. If I remember correctly on the left side.
Very easy to identify. Remove the multi conector from the blue sleeve and you'll see it clearly numbered..
Can't get it wrong really..
Reactions: Wayne p and Jamie1087
I've sorted it thank you ,, now have fully functioning dis stalk and mfsw ..
10
912
579
I
871
i_786_i
I
