Looking for my missing 100 bhp
slowcoach3
Devon
HI all, I have a stage 2 mapped APY that is currently missing a fair chunk of boost. My gauge shows -25inhg on idle, so I'm assuming no vac leaks, on boost it normally struggles to 8-10 psi , very occasionally it might peak at somewhere between 12-15 but that's rare. Last week it was peaking at 23 and holding :(
It has a new Bosch maf, tried swapping out n75 with no success. There's no codes present and visually checking boost pipes and the simplified pcv shows nothing suspect. 4th gear run from 2k to as high as I could go on a public road showed a measly 140 g's so approx 175 bhp!
Any ideas or suggestions appreciated,
4th gear run from 2k...
Try to run it on 2nd gear from 2k till red line.
I will do but it will show less g's than in 4th I'd have thought.
Unfortunately not, laptop battery has died so I can only use it when plugged in. Maf readings are from my crappy torque app! I disconnected the n75 and it hits 6psi in each gear, it seems to do this with less effort than when it's plugged in!
Ideally I'd like to log actual versus requested boost but need a new laptop battery first lol
