Hi all, after installing front and rear footwell lights to my 2014 sline sportback I tried today to code them in.
Following @DJAlix coding, the car has allowed me to carry out..
Interior Lighting MMI Menu
Footwell Lights
When I try to make the adaptions it says a security code is required.
My 1st adaption also has options to enable instead of installed, I never like to assume anything, can someone confirm that this would change to enable.
@DJAlix mentioned when he posted his coding that if LEDs are not fitted then Leuchte channels also need changed. As mine are LED can I ignore the following
- 5F - Information Electr
- Adaptations
- (15)-Vehicle function list BAP-interieur_light_0x08 = Activated (should be set as factory default)
- (6)-Vehicle menu operation-menu_display_ambient_illumination = activated
- (7)-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off = not activated
- (8)-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high = activated
- (9)-Vehicle menu operation-menu_display_ambient_illumination_standstill = not activated
- (10)-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer = not activated
- Reset MMI
Footwell Lights
- 09 Cent Elect
- Long Coding
- Byte 5
- Bit 7 = Active (Footwell Lights Installed)
- 09 Cent Elect
- Adaptations
- (6)-Ambient lighting-Innenlichtinszenierung = Installed (ambient lighting - interior lighting)
- (1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum = 100% (default value setting profile footwell)
- (3)-Ambient lighting-Defaultwert Ambienteprofil Vorn = 100% (default value setting profile front)
- (1)-Leuchte30FR LC72-Lasttyp 30 = 46 - LED Kleinleistung
- (2)-Leuchte30FR LC72-Lampendefektbitposition 30 = 0
- (3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 = 2
- (4)-Leuchte30FR LC72-Lichtfunktion A 30 = Footwell Light
- (6)-Leuchte30FR LC72-Dimmwert AB 30 = 100
- (7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30 = Always
- 1)-Leuchte30FR LC72-Lasttyp 30 = 46 - LED Kleinleistung
