As said by HHS3 above, always difficult to pin down an intermittent starting issue. My guess is that if the car is not misfiring (either generally or immediately after starting) and is otherwise running smoothly - these problems are often connected to the mixture being marginally too weak for a cold start. In my experience, the most tricky and complex sensor which can cause this issue (whilst not always causing an error code and/or "engine error light") is the MAF sensor.
