what do you uys and girls think of this...
VAG-COM Version: Release 504.1-UD
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 17 22 35 37 45 54 55 56
Address 01: Engine
Controller: 8N0 906 018 BH
Component: 1.8L R4/5VT 0001
Coding: 10710
Shop #: WSC 13872
WAUZZZ8L031203501 AUZ7Z0B2120910
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC
Controller: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8L0 920 980 R
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 01444
Shop #: WSC 00081
Address 22: AWD
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0010
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15210
Shop #: WSC 01236
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00014
Shop #: WSC 01236
Address 56: Radio
Controller: 8L0 035 152 B
Component: chorus II GRO 0008
Coding: 00202
Shop #: WSC 01236
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------------------------
do i need a new MAF?i hav e cleaned the old one to no avail, acceleration seams to be intermitent
thanks
Address 01: Engine
Coding: 10710
Shop #: WSC 13872
3 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
Coding: 18448
Shop #: WSC 01236
Coding: 00041
Shop #: WSC 01236
Coding: 01444
Shop #: WSC 00081
Address 22: AWD
Coding: 15210
Shop #: WSC 01236
3 Faults Found:
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 01236
Address 56: Radio
Coding: 00202
Shop #: WSC 01236
1 Fault Found:
thanks
