97 2.8 Quattro clutches
Avant1
Slow and Steady
Northern Ireland
Need to replace the above on a newly acquired car
What other variants share the same clutches ? Hoping a Skoda equivalent might be cheaper
2.8 V6 ACK engine code
I'm not sure why you think a skoda clutch would be cheaper, if its the same part number its the same price.
Autodoc sell the clutch for about £100
True but thanks for pointing me in the right direction
Hi
Just to ask I’m reading that the gearbox Oil needs to be at 35deg when being added
Is there a diy way to achieve this ?
Is it imperative that’s it’s exact ?
Don’t want to screw it up hence the questions
gear oil temperature is usually for automatic transmissions?
If its an Auto, you read the box temperature using VCDS
