My A5 Small improvements
Looking good mate, did you replace the side mirrors or are they wrapped?
I bought them from ebay but they didn't fit like the factory ones so ended up painting my original covers with aluminium paint
Reactions: S32B
Just another quick improvement, fed up of dirt spraying up through the suspension plastic covers.
C6701A31 4021 4223 ABB7 28F5880EE9F9
Solid red on rev counter S Diles
D017F46A 0F75 4F53 929E 2B021B8AC04E
Reactions: cata_adc
Not the modification i planed to do this weekend but looks a lot better for it.
Decided to paint all the brake calliper’s
I removed the rears but chickened our with fronts and masked around everything.
Would really like to do the Auto Hold modification - had it on my Golf R and really miss it on the S5 plus the blank button doesnt sit well with me. My only challenge is I have no confidence in my ability to do it without cocking it up. So if you live near Warrington and have done the mod I make a mean brew and have fancy M&S biscuits :)
Speed cameras added to MMI mobile, Gatso, Average, Traffic light
9025904B 2DC8 4716 B276 992EA21B670E
Tha G meter doesn’t work on my car as it’s missing other coding or sensors, I use OBDeleven so you can use the app or go into dashboard 17 Adaptations - Acceleration Display - set to yes.
I have got the speed cameras working but there should be 4 files but I have around 30 so I need to find a different way of downloading them, once I sort it I’ll Post how it’s done.
Yesterday I managed to get the audible warning to work as you approach each type of camera.
Reactions: Lmarls
Loving all the retro fits you are doing, out of curiosity how much and how easy is it to do the ALA stalk swap over?
Was the speed cameras done via OBDEleven long coding?
Thanks Aaron.
You can add lane assist and change the 'severity' of its impact without the stalk but just cant fully turn it off. Personally I really didnt like it and had it removed a few weeks later.
If you press traction control into sport it disables the lane assist. That’s how i turn it on and off at the moment.
Didnt know that! Never found it that useful really it seem to sometimes move me when I didnt want it too or almost fight against my input.
Reactions: A12RNX
Thanks Aaron.
The lane assist Stalks are around £250 from Audi, fitting is not that hard but you need someone with VCDS to set the steering angle sensor as it can`t be done with OBDeleven but you can then use OBD to code in lane assist.
I used https://www.pocketgpsworld.com/ to get the camera data base then use this app to load them onto https://github.com/mcaddy/audipoi/blob/master/Releases/SpeedCameraToPoi/v0.9.1.zip?raw=true then copy to SD card then load them into MMI
I wasn't a fan until i fitted the stalks with on/off button as i found it annoying on twisty country roads, now i have it set to high on every setting and its very good especially on motorway driving.
Reactions: A12RNX
Today I had half a day off work and decided to fit my Audi front & rear traffic cam recorders, very impressed at the quality.
Fitting is not the easiest and no instructions are included.
But it’s all working in car and on phone App.
8CC7AF3D DCC5 4B8A B514 9C383B356B9F
0E829BA8 69E5 4AED B117 A9DBF82D23E8
60B0589A 7119 49A9 B98C FD5E325AC214
Reactions: Craig999
Yes I used the Kufatec dongle for TSR.
I used https://www.pocketgpsworld.com/to get the camera data base then use this app to load them ontohttps://github.com/mcaddy/audipoi/blob/master/Releases/SpeedCameraToPoi/v0.9.1.zip?raw=true then copy to SD card thenload them into MMI
Unfortunately this doesn't work on my 2017 S5, when I try to update the Pro's using the SD card I get "The update data are not compatible or are outdated."
Can't create the files using My Audi as the special destinations part says it's down or overloaded all the time
Got the Auto Hold and TZR kits coming from Kufatec and waiting for a price from HappyDayz to do the Auto fold mirrors and seat memory.
Andy
Andy
Did you get the file from pocketgpsworld ? which file did you load ie garman ?
Hi Dave,
I used the small application to download the files from PocketGPSWorld and create the SD card.
Also tried via My Audi but the special destinations bit is always offline and says it's overloaded so couldn't use that.
Cheers, Andy
If you drop me your email i`ll try sed you the file i used.
my next modification is to add memory seats, just looking at wiring diagrams to see what i need.
Hi Dave,
I don't have access to the diagrams but HappyDayz is pricing this up for me along with the folding mirrors, I've also enquired about the side assist at the same time.
I have the massage electric seats that come in the S5 but was amazed they don't have memory as standard, same as the convenience key. Thankfully ours has the convieience key and I suspect the memory seats is just the buttons, mount and a connection to the door control and coding. Not got anything to reference though as the new models only have manuals and diagrams online I believe?
I've sent you a pm with my email for the cameras
Cheers, Andy
