Andy avant b5
- Joined
- May 14, 2017
- Messages
- 946
- Reaction score
- 131
- Points
- 43
Hi there is there a way to check for a boost leak on vag. Com I've only got the free version cheers
If in limp mode stays in limp modetill reset or battery disconnected sounds more like leak or misfireIt goes into limp mode but then after about 20 seconds full boost is back
I had similar issue and was dodge coil pack and shitted up plugsIt's not a mis fire must be a boost leak
Sounds like mine when had dodge coil even though had no code come upThe plugs are new was doing it on the old ones and new ones it's only when I give it some cuts boost for about 20 seconds then comes back during that time engine runs sweet but boost cut in half
Some fault code readers aren't best as dont bring up all the codes in the end I got vag com as saved me a fortune in the long runReally OK you might be right going to boost leak test it anyway then take it from there
I got mine cheap off gumtree posted full versionJust got mine but only got the cheap eBay lead and the free software but not set it up yet
