Oil pump tensioner
SamHendry
When I done the oil pump on my s3 noticed tensioner was worn, wasnt sure how to change it at the time so left it now its bugging me..
Some insight of what's involved would be helpful, can it be done with just sump off?
nope... need to remove the front crank seal cover to remove so thats damper pulley, crank pulley and making sure the timing bet is aligned etc...
Do you need to remove sump aswell tuffty or can it all be done via crank cover?
How do folk remove the crank bolt on there driveway?
http://workshop-manuals.com/audi/a3...ing_sealing_flanges_and_flywheel/drive_plate/
Never done one that way so don't recall if its possible but tbh if I was doing it I would prob remove it to make it easier
You will need a new crank bolt as they are one use... you will be best served replacing the crank seal too as it could get damaged and I doubt it will reseal once disturbed
There are various tools available to lock the crank but this is what Bill and I knocked up to take mine off after gearchangegate
http://www.audi-sport.net/xf/threads/my-minor-modding-thread.76389/page-69#post-2225744
Reactions: SamHendry
Cheers tuffty not as straight forward as I wished, trick idea welding that steel box section to the crank, maybe look into doing something similar myself.
907
800
9
881
