Which Engine Oil
doganicmihai
GB
Hello... a small quick question. I have an audi A4 B6 1.9TDI quattro(130 hp ). It has 187000 miles on clock and the engine oil must be changed now. Wich engine oil would you recommend for this milleage. Tend to say that last time i used CarLube 10w40 , as recommended by my uncle. Should i keep using this one or i should go for an 5w40 oil?
Thank you
Sent from my SM-N950F using Tapatalk
*** , your uncles incompetent advice has probably started irriversable cam lobe wear .
VW 507.00 spec .
Might as well go for the proper oil IMO. Depends on if you are doing longlife (507.00) or fixed service intervals (505.01) (I'd recommend fixed at this age / mileage though).
Anyway, Genuine oil isn't that expensive really.
Longlife (507.00): http://www.ebay.co.uk/itm/Genuine-Q...831042&hash=item25c5a71917:g:MzoAAOSwj~dZ4JrH
Fixed (505.01 PD Spec): https://www.ebay.co.uk/itm/GENUINE-...064236&hash=item3b007b313b:g:fqYAAOSwvD5aKWMk
Both links are sold by REAL VAG dealers, so it's highly unlikely to be the wrong stuff. I have used the 505.01 stuff for the last few years in my 2.0 PD Alhambra without incident. And is about as cheap as you can buy decent oil. And that's what I would recommend for you.
Do yourself a favour, and buy a GENUINE oil filter too. It'll be a couple quid more expensive than the cheapest one you can buy, but hey, whats a couple quid to make sure your engine is running the best it can? Don't be tempted to "cheap out" and save what? A fiver between the oil and the filter? Do it right.
I only bought proper spec Shell oil for my A4 recently because it was 10L for £30 from ECP in some deal, otherwise I would have just bought Genuine oil.
Reactions: Roland Wong
Hey xs2man , thank you very much for your advice. Could you please tell me how it is called the genuine oil filter ? :) last time i used all Mann filters cause i was told tgey are the best...
Thank you
Just nip into Audi and buy a filter.
Reactions: doganicmihai
637
